[GRASS-dev] [bug #5192] (grass) tclsh error in
/grass-6.2.0RC2/etc/gm/gm.tcl
Request Tracker
grass-bugs at intevation.de
Sat Oct 7 11:19:36 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5192
Subject: tclsh error in /grass-6.2.0RC2/etc/gm/gm.tcl
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
Hello,
I packaged GRASS 6.2.0RC2 for Pardus -Linux. When I start GRASS, I get this error below.
And tcl version is 8.5_alpha3...
murat at pardus grass $ grass
Cleaning up temporary files.....
Starting GRASS ...
Welcome to GRASS 6.2.0RC2 (2006)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: gis.m &
When ready to quit enter: exit
GRASS 6.2.0RC2 (samples):~/Desktop/grass > Error in startup script: bad variable name "coords(1)": upvar won't create a scalar variable that looks like an array element
while executing
"global coords($mon)"
(procedure "MapCanvas::pointer" line 5)
invoked from within
"MapCanvas::pointer $mon"
(procedure "MapCanvas::create" line 226)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 69)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/var/tmp/pisi/grass-6.2.0_rc2-3/install/opt/grass-6.2.0RC2/etc/gm/gm.tcl" line 521)
-------------------------------------------- Managed by Request Tracker
