[GRASS-dev] adding 'desc' to dbf sql driver
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 10 04:29:35 EDT 2006
Glynn Clements wrote:
> Moritz Lennert wrote:
>>> Looks good to me. In the yac.y patch, you don't need to duplicate the
>>> code for ORDER BY NAME and ORDER BY NAME ASC.
>> How do I take care of the case where neither asc nor desc are given in
>> the sql ? This should default to asc, but this:
>> +y_order_asc:
>> + NAME | NAME ASC {
>> sqpOrderColumn( $1, SORT_ASC ); }
>> does not work, i.e. results of 'order by' without asc are not sorted.
>> So how does this need to be formulated ?
> y_order_asc:
> NAME { sqpOrderColumn( $1, SORT_ASC ); }
> | NAME ASC { sqpOrderColumn( $1, SORT_ASC ); }
> The | splits a definition into separate rules. Each rule has its own
> action; if none is given, the default action is "{ $$ = $1; }". So, in
> your original version, the specified action only applied to the
> "NAME ASC" rule, while "NAME" got the default action.
This is how I did it in fact. Thanks.
I have just committed the series of changes necessary for the support of
the ASC/DESC keywords in the ORDER BY clause in the dbf driver.
For me it works, so I thought the best would be to commit it so that
others could test it.
The only issue I still have is with the test case in lib/db/sqlp/test/,
but I don't know if that is a problem with my code, or with the testing...
Input row: -->>SELECT c1,c3 FROM pok order by c1 ASC;
Input statement: -->>SELECT c1,c3 FROM pok order by c1 ASC<<--
********** SQL PARSER RESULT **********
INPUT: SELECT c1,c3 FROM pok order by c1 ASC
COMMAND: SELECT
TABLE: pok
COLUMN 1: c1
COLUMN 2: c3
./test2: line 15: 32474 Done echo "SELECT c1,c3 FROM
pok where c3 <> 34 and c5 = 2.3;
INSERT INTO pok VALUES ( 'abc', 32, 56.7 );
INSERT INTO pok ( c1, c2,c3) VALUES ( 'abc', 32, 56.7 );
INSERT INTO pok ( c1, c2,c3) VALUES ( 'abc', -32, -56.7 );
upDAte pok SET c2 = '5', c3 = 1 WHERE c1 = '1' AND c5 = 6;
delete FROM pok WHERE c1 = '1' and c2=3 AND c5 <= 4.35;
CREATE TABLE pok ( c1 INT, c2 VARCHAR (5), c3 DOUBLE );
DROP TABLE pok;
ALTER TABLE pok ADD COLUMN id int;
ALTER TABLE pok ADD popis varchar(10);
UPDATE pok SET c2 = NULL, c1=c2, c3=(-c3+12)/c1 where c1 NOT NULL;
update pok set c1=c2,c2=c1,c3=NULL where c1+2>1/cat+0.5 and not (c1=1 or
c2=2);" 32475 Segmentation fault | ./sqlptest
Moritz
