[GRASS-dev] extraneous files in grass-6.2.0RC2.tar.gz & 6.2.0
release plans
Hamish
hamish_nospam at yahoo.com
Sun Oct 8 00:46:46 EDT 2006
"lib/init/gis_set.tcl.orig" shouldn't be there.
$ tar tzf grass-6.2.0RC2.tar.gz | grep gis_set.tcl
grass-6.2.0RC2/lib/init/gis_set.tcl.orig
also, visualization/nviz/scripts/nviz2.2_script.orig
they don't seem to be in CVS so problem is just left over local files.
("? path/filename" at start of processing with "cvs update -q")
In 6.3-cvs I have removed the tcltk web browsers from NVIZ and (the
duplicate) in lib/init/. Both were previously made redundant by Markus.
This saves ~ 240kb in the source tree.
RC2 builds fine on Debian/Sarge (tcltk 8.3).
For me, the welcome text is now large, but not huge:
Welcome to GRASS GIS Version 6.2.0RC2
The world's leading open source GIS
Select an existing project location and mapset
or define a new location
known release to-dos:
[high priority]
- refine the press release
- make v.digit 8.3 compatible, note "gis.m may need 8.4" in REQUIREMENTS.html
[minor]
- r.le.* G_calloc() before G_gisinit()
[optional]
- apply v.buffer patch? (trade bad known bug for lightly tested band-aid)
- remove TclTk web browser from NVIZ & lin/init/ (merge from HEAD)
- anything else?
Hamish
