[GRASS-dev] what can come before G_gisinit()?
Sun Oct 8 02:18:27 EDT 2006
Glynn Clements wrote:
> > is it ok to call G_calloc() before G_gisinit()?
> No.
> G_calloc() calls G_fatal_error() if calloc() fails. G_fatal_error()
> calls G_program_name(), which uses the program name set by
> G_gisinit().
Ok, r.le needs some more fixing then, e.g. r.le.patch
main.c:
struct CHOICE *choice;
int main(){
  struct GModule *module;
  /* allocate space for the choice data structure */
  choice = (struct CHOICE *)G_calloc(1, sizeof(struct CHOICE));
  G_gisinit();
  module = G_define_module();
  user_input(argc,argv);
  fprintf(stderr, "\tMAP:\t  %s\n", choice->fn);
input.c:
extern struct CHOICE *choice;  // again!!
void user_input (int argc, char **argv) {
   struct Option *name;
   struct Option *sampling_method;
   G_gisinit(argv[0]);   // again!!
   name = G_define_option();
   sampling_method = G_define_option();
   if (G_parser(argc,argv))
      exit(EXIT_FAILURE);
   G_strcpy(choice->fn, name->answer);
   choice->wrum = sampling_method->answer[0];
patch.h:
struct CHOICE {
        char fn[30], reg[30],out[30],
             wrum;
        int  core2, size2, shape2,
             edge, fb, coremap, units;
        int  perim2, trace, patchmap;
        int  Mx[4];
        int  att[9], size[9], shape[8],
             boundary[5], perim[8], core[11];
/** main.c **/
void  user_input();
too many choices,
Hamish
