[GRASS-dev] what can come before G_gisinit()?
Tue Oct 17 08:05:10 EDT 2006
Hamish wrote:
> > > is it ok to call G_calloc() before G_gisinit()?
> > No.
> > G_calloc() calls G_fatal_error() if calloc() fails. G_fatal_error()
> > calls G_program_name(), which uses the program name set by
> > G_gisinit().
> Ok, r.le needs some more fixing then, e.g. r.le.patch
> main.c:
> struct CHOICE *choice;
> int main(){
>   struct GModule *module;
>   /* allocate space for the choice data structure */
>   choice = (struct CHOICE *)G_calloc(1, sizeof(struct CHOICE));
>   G_gisinit();
I've moved the G_gisinit() to the beginning of main, before the
G_calloc() call ...
> input.c:
> extern struct CHOICE *choice;  // again!!
> void user_input (int argc, char **argv) {
>    struct Option *name;
>    struct Option *sampling_method;
>    G_gisinit(argv[0]);   // again!!
... and removed the extraneous G_gisinit() from user_input().
