[GRASS-dev] gis.m in wingrass: using where clause in d.vect
causes error :can't read "_data(.gronsole.gronsole,9,
donecmd)": no such element in array
Moritz Lennert
mlennert at club.worldonline.be
Sun Oct 8 04:30:22 EDT 2006
On Sun, October 8, 2006 04:59, Hamish wrote:
> Moritz Lennert wrote:
>> Using a where clause in vector display in gis.m causes the following
>> error under WinGRASS. Any suggestions ?
>> (WinGRASS version 2006-09-17)
>> can't read "_data(.gronsole.gronsole,9,donecmd)": no such element in
>> array can't read "_data(.gronsole.gronsole,9,donecmd)": no such
>> element in array
>> while executing
>> "set donecmd $_data($path,$ci,donecmd)"
> also seen on Linux, GRASS versions 6.3 and 6.2-rc1 IF you put the
> query in the "query cat values" box by mistake.
I am not near a windows box right now, but I am quite positive that this
is not the problem here. I entered the query in the where box, not the cat
box.
But I'll make sure tomorrow.
Moritz
