[GRASS-dev] gis.m in wingrass: using where clause in d.vect
causes error :can't read "_data(.gronsole.gronsole,9,
donecmd)": no such element in array
Moritz Lennert
mlennert at club.worldonline.be
Sun Oct 8 04:37:49 EDT 2006
On Sun, October 8, 2006 10:30, Moritz Lennert wrote:
>>> Using a where clause in vector display in gis.m causes the following
>>> error under WinGRASS. Any suggestions ?
>>> (WinGRASS version 2006-09-17)
>>> can't read "_data(.gronsole.gronsole,9,donecmd)": no such element in
>>> array can't read "_data(.gronsole.gronsole,9,donecmd)": no such
>>> element in array
>>> while executing
>>> "set donecmd $_data($path,$ci,donecmd)"
>> also seen on Linux, GRASS versions 6.3 and 6.2-rc1 IF you put the
>> query in the "query cat values" box by mistake.
> I am not near a windows box right now, but I am quite positive that this
> is not the problem here. I entered the query in the where box, not the cat
> box.
> But I'll make sure tomorrow.
Actually I just managed to test (Qemu over NX, quite an experience ;-) ),
and I can confirm that the problem is with the sql query box. So it is not
the same problem as the one described by Hamish.
Moritz
