[GRASS-dev] gis.m in wingrass: using where clause in d.vect
causes error :can't read "_data(.gronsole.gronsole, 9,
donecmd)": no such element in array
Moritz Lennert
mlennert at club.worldonline.be
Mon Oct 9 04:33:32 EDT 2006
Moritz Lennert wrote:
> On Sun, October 8, 2006 10:30, Moritz Lennert wrote:
>>>> Using a where clause in vector display in gis.m causes the following
>>>> error under WinGRASS. Any suggestions ?
>>>> (WinGRASS version 2006-09-17)
>>>> can't read "_data(.gronsole.gronsole,9,donecmd)": no such element in
>>>> array can't read "_data(.gronsole.gronsole,9,donecmd)": no such
>>>> element in array
>>>> while executing
>>>> "set donecmd $_data($path,$ci,donecmd)"
>>> also seen on Linux, GRASS versions 6.3 and 6.2-rc1 IF you put the
>>> query in the "query cat values" box by mistake.
>> I am not near a windows box right now, but I am quite positive that this
>> is not the problem here. I entered the query in the where box, not the cat
>> box.
>> But I'll make sure tomorrow.
> Actually I just managed to test (Qemu over NX, quite an experience ;-) ),
> and I can confirm that the problem is with the sql query box. So it is not
> the same problem as the one described by Hamish.
Huidae or Glynn, any ideas on this ?
Moritz
