[GRASS-dev] gis.m in wingrass: using where clause in d.vect
causes error :can't read "_data(.gronsole.gronsole, 9,
donecmd)": no such element in array
William Kyngesburye
woklist at kyngchaos.com
Sun Oct 8 18:56:22 EDT 2006
I was holding off on replying to this, waiting for a windows reply.
And, this issue was brought up mid-Sept also, I guess a solution
wasn't found then.
The Mac problem had to do with using TclTk Aqua vs. X11. For Aqua
the osxaqua=1 env must be set, or you get this error. Maybe if you
look at what setting osxaqua makes GRASS do differently with the
GUI? There are a couple settings in init.sh dependent on osxaqua, I
never looked to see if it's used elsewhere.
This is the Mac bug:
http://intevation.de/rt/webrt?serial_num=5096&display=History
On Oct 9, 2006, at 3:38 AM, Michael Barton wrote:
> Something along this line popped up in a Mac installation. I think
> it was a
> colleague of William Kyngesburye, so I'm copying him here. In that
> case
> there was something missing in the installation that finally turned
> out to
> be the problem.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Moritz Lennert <mlennert at club.worldonline.be>
>> Date: Sun, 8 Oct 2006 10:30:22 +0200 (CEST)
>> To: Hamish <hamish_nospam at yahoo.com>, <michael.barton at asu.edu>
>> Cc: <grass-dev at grass.itc.it>
>> Subject: Re: [GRASS-dev] gis.m in wingrass: using where clause in
>> d.vect
>> causes error :can't read "_data(.gronsole.gronsole,9, donecmd)":
>> no such
>> element in array
>> On Sun, October 8, 2006 04:59, Hamish wrote:
>>> Moritz Lennert wrote:
>>>> Using a where clause in vector display in gis.m causes the
>>>> following
>>>> error under WinGRASS. Any suggestions ?
>>>> (WinGRASS version 2006-09-17)
>>>> can't read "_data(.gronsole.gronsole,9,donecmd)": no such
>>>> element in
>>>> array can't read "_data(.gronsole.gronsole,9,donecmd)": no such
>>>> element in array
>>>> while executing
>>>> "set donecmd $_data($path,$ci,donecmd)"
>>> also seen on Linux, GRASS versions 6.3 and 6.2-rc1 IF you put the
>>> query in the "query cat values" box by mistake.
>> I am not near a windows box right now, but I am quite positive
>> that this
>> is not the problem here. I entered the query in the where box, not
>> the cat
>> box.
>> But I'll make sure tomorrow.
>> Moritz
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
