[Fwd: [GRASS-dev] [bug #5195] (grass) ps.map sets encoding to iso-8859-1]
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 9 10:34:47 EDT 2006
Since the Gforge tracker is now operational, should bugs be reported there ?
Will these bugs still be sent to the dev list ?
Moritz
-------- Original Message --------
Subject: [GRASS-dev] [bug #5195] (grass) ps.map sets encoding to iso-8859-1
Date: Mon,  9 Oct 2006 16:29:30 +0200 (CEST)
From: Request Tracker <grass-bugs at intevation.de>
Reply-To: Request Tracker <grass-bugs at intevation.de>
To: grass-dev at grass.itc.it
this bug's URL: http://intevation.de/rt/webrt?serial_num=5195
Subject: ps.map sets encoding to iso-8859-1
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs_head_20060921
On line 92 of ps/ps.map/prolog.ps the encoding is set to ISOLatin1Encoding.
If I understand correctly (and some testing confirms this) this means
that the instructions file for ps.map has to be encoded in iso-8859-1
(or similar) to work, i.e. to be able to print accented characters. If
you are in a UTF-8 environment, ps.map creates a ps file which doesn't
show correct accented characters be it in iso or in utf.
Is there any reason why ps.map hardcodes the encoding ? Is it possible
to automatically use the users encoding ?
Moritz
-------------------------------------------- Managed by Request Tracker
grass-dev mailing list
http://grass.itc.it/mailman/listinfo/grass-dev
