[GRASS-dev] small bugfix for d.vect.thematic
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 9 15:54:29 EDT 2006
I fixed a small bug in d.vect.thematic which caused it to fail if the
vector map was linked to a db via a different driver than the one declared
by db.connect:
http://grass.itc.it/pipermail/grass-commit/2006-October/024608.html
This should probably be backported to 6.2.
Moritz
