[GRASS-dev] [bug #5196] (grass) v.what.vect: wrong option description
Request Tracker grass-bugs at intevation.de
Mon Oct 9 16:44:25 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5196
Subject: v.what.vect: wrong option description
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 2006.10.07
v.what.vect's option that reads:
"layer=integer Layer where to add column"
should rather read:
"layer=integer Layer where to upload query results"
because v.what.vect doesn't add columns - the manual reads: "The upload column into which the query results are stored must be present in the vector point map or added with v.db.addcol."
Maciek
-------------------------------------------- Managed by Request Tracker
