[GRASS-dev] r3.in.ascii suggestion
Sören Gebbert soerengebbert at gmx.de
Tue Oct 10 04:40:35 EDT 2006
Hamish schrieb:
> Hi, a short wishlist for r3.in.ascii:
> I suggest changing r3.in.ascii's nv= parameter to default to '*' instead
> of the word 'none', as is done in r.in.ascii.
Maybe "*" is more useful then "none". But if no null values are present
and "*" is set as default, the import is a bit slower (null values are
checked for each voxel).
> also, type= should be changed from "default,float,double" to
> "default,integer,float,double" or "default,CELL,FCELL,DCELL"?
> (or 3D DCELL map type equivalents)
G3d lib supports only float and double values, no integer.
The type names are G3D_FLOAT and G3D_DOUBLE.
This will hopefully change when the raster and g3d lib are
new implemented as one library.
> Why is "precision=" there at all? Is the module adapted from r.out.ascii
> or something?
Precision is used for creating a new g3d map -> G3d_openNewParam (...)
and is needed by G3d_setCompressionMode(...).
I  have no clue how the compression works in the g3d lib. :(
The parameters:
type   Data type used in the output file
precision   Precision used in the output file (default, max, or 0 to 52)
compression   The compression method used in the output file
tiledimension   The dimension of the tiles used in the output file
are set with G3d_setStandard3dInputParams () and used with
G3d_getStandard3dParams ( ... ).
If you want to change something, you need to modify
grass6/lib/g3d/g3dparams.c.
> could the "data source" metadata line be set to the input filename?
> (example in r.in.xyz)
input_opt->gisprompt   = "old_file,file,input";?
> The help page needs cleaning, and perhaps a little 3x3x3 example.
Added to my todo list.
> A r3.univar module would be nice too.
This is already on my wish and todo list. :)
Best regards
Soeren
> thanks,
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
