[GRASS-dev] r3.in.ascii suggestion
Wed Oct 11 02:08:51 EDT 2006
HB:
> > could the "data source" metadata line be set to the input filename?
> > (example in r.in.xyz)
SG:
> input_opt->gisprompt   = "old_file,file,input";?
No, the "hist" file info seen at the end of r.info and r3.info.
I've now updated r3.in.ascii and r3.to.rast for this.
Please test r3.to.rast especially, each raster level should now show
the depth range it came from. I don't have any real multi-level data
to test with..
Hamish
