[GRASS-dev] r.mapcalc and g.remove --v/q issues
Martin Landa landa.martin at gmail.com
Wed Oct 11 13:51:37 EDT 2006
Hi all,
trying to reconcile your notes I prepared the new patch for g.remove,
I will commit it (or prepare a new one) after your full feedback...
export GRASS_VERBOSE=2
Raster map:
g.remove rast=t;echo $?
Remove <t>
WARNING: Raster map <t> not found
WARNING: <t> nothing removed
0
r.mapcalc t=1 2>/dev/null;g.remove rast=t;echo $?
Remove <t>
0
3D raster map:
g.remove rast3d=t;echo $?
Remove <t>
WARNING: Raster 3d map <t> not found
0
r3.mapcalc t=1 2>/dev/null;g.remove rast3d=t;echo $?
Remove <t>
0
Vector map:
g.remove vect=t;echo $?
Remove <t>
WARNING: Vector map <t> not found
0
v.random out=t n=1 2>/dev/null;g.remove vect=t;echo $?
Remove <t>
0
Region:
g.remove region=t;echo $?
Remove <t>
0
g.region save=t;g.remove region=t;echo $?
Remove <t>
0
Best, Martin
2006/10/11, Maciej Sieczka <tutey at o2.pl>:
> Glynn Clements wrote:
> > "not found" is only one failure mode. It's also possible that some or
> > all of the files which make up the map exist but couldn't be removed.
> > There are essentially 4 cases:
> > 1. Nothing found.
> "WARNING: Raster map <dummy> not found"
> > 2. Some files found, none removed.
> "ERROR: Raster map <dummy> found, but none of it's components could be
> removed:
> (here comes the list)"
> > 3. Some files found, some removed.
> "ERROR: Raster map <dummy> found, but only the following components
> where removed:
> The following components couldn't be removed:
> > 4. Some files found, all removed.
> "WARNING: Raster map <dummy> removed"
> > #2 and #3 are unarguably failures, while #4 is unarguably success.
> > Whether #1 is a failure or success is debatable. It should certainly
> > result in notification, probably even at minimum verbosity, but it's
> > less clear that it should result in a non-zero exit code.
> I agree: exit code 0 and a warning - even at min. verbosity.
> > If it fails to remove some components of a map, it's necessary for the
> > user to be told the details, IMHO, as the user is going to have to fix
> > the problem manually.
> I agree. But the situation #2 or #3 is quite unlikely - one would need
> to lose his write access for some files that make the given GRASS
> raster map, while retaining his write acces to it's other components
> (is there a possible scenario for this within GRASS?). Or he would have
> to corrupt his raster map by removing some of it's components manually,
> outside the GRASS.
> And as the prevailing real life situations are #1 and #4, g.remove by
> default shouldn't bother the user with the internals of GRASS raster
> map format. Like it doesn't in case of vector format, although it also
> consists of several files AAMOF.
> Maciek
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061011/1e582bdb/g_remove3.diff.gz
