[GRASS-dev] [bug #5204] (grass) grass6.3 - gis.m: can't read
Michael Barton michael.barton at asu.edu
Thu Oct 12 16:34:03 EDT 2006
To clarify, what I suggest below doesn't work. However, I've fixed the
problem in the cvs.
Now I need to find out why d.vect.thematic bombs completely on my Mac.
"which awk" is in both d.vect.thematic and v.univar.sh and gives an error on
my system now.
If I comment this out, I get subsequent errors in the sql statement parsing.
Anyone have any ideas?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Michael Barton <michael.barton at asu.edu>
> Date: Thu, 12 Oct 2006 11:02:49 -0700
> To: Paolo Cavallini via RT <grass-bugs at intevation.de>,
> <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] [bug #5204] (grass) grass6.3 - gis.m: can't read
> This probably has to do with a recent update (not by me) to use generic
> system-wide fonts. The TclTk code *was* using a TclTk font as a default, and
> lifting a line height value from the font spec (variable lineht). This has
> been changed to use the default fonts specified in option.tcl. In general,
> this is fine, but I suspect that either those fonts need to specified a bit
> differently or the variables in which the default font strings are stored
> needs to be declared as global in the thematic.tcl code in the correct
> procedure.
> I'll look into it, but just discovered that my version of d.vect.thematic is
> no longer working because of a "which awk" statement that was added
> (when??). This test fails on my Mac, even though I have awk. It looks like
> "which" is a csh term, at least on my system, not a bash term. I don't know
> at the moment if this is an issue my Mac binary or with the script.
> So I'll have to futz with the whole thing to test. If someone else wants to
> do some checking too while I'm trying to deal with the awk thing, I suggest
> the following. In thematic.tcl, change...
> proc GmThematic::create { tree parent } {
>     variable opt
>     variable count
>     variable dup
>     variable lfile
>     variable lfilemask
>     variable optlist
>     global iconpath
> to...
>     variable opt
>     variable count
>     variable dup
>     variable lfile
>     variable lfilemask
>     variable optlist
>     global iconpath
>     global introfont
>     global bolddefault
>     global default
> ...and see what happens.
> Michael
> phone: 480-965-6213
> fax: 480-965-7671
>> From: Request Tracker <grass-bugs at intevation.de>
>> Reply-To: Request Tracker <grass-bugs at intevation.de>
>> Date: Thu, 12 Oct 2006 15:59:49 +0200 (CEST)
>> To: <grass-dev at grass.itc.it>
>> Subject: [GRASS-dev] [bug #5204] (grass) grass6.3 - gis.m: can't read
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=5204
>> Subject: grass6.3 - gis.m: can't read
>> Platform: GNU/Linux/x86
>> grass obtained from: CVS
>> grass binary for platform: Compiled from Sources
>> GRASS Version: cvs_head_20061012
>> Trying to display a thematic layer in the GIS Manager on any vector map in
>> the
>> spearfish location, I get
>> can't read "lineht": no such variable
>>     while executing
>> "expr {$lineht * 2}"
>>     (procedure "GmThematic::tleg_item" line 20)
>>     invoked from within
>> "GmThematic::tleg_item $mon $id"
>>     (procedure "GmThematic::display" line 73)
>>     invoked from within
>> "GmThematic::display $node $mod"
>>     ("thematic" arm line 2)
>>     invoked from within
>> "switch $type {
>>         group {
>>             GmGroup::display $node $mod
>> raster {
>> GmRaster::display $node $mod
>> labels {
>> GmLabels::disp..."
>>     (procedure "GmTree::display_node" line 7)
>>     invoked from within
>> "GmTree::display_node $n $mod"
>>     (procedure "GmGroup::display" line 22)
>>     invoked from within
>> "GmGroup::display "root" $mod"
>>     (procedure "MapCanvas::runprograms" line 63)
>>     invoked from within
>> "MapCanvas::runprograms $mon [expr {$mymodified != 0}]"
>>     (procedure "MapCanvas::drawmap" line 38)
>>     invoked from within
>> "MapCanvas::drawmap $mon"
>>     (procedure "MapCanvas::display_server" line 9)
>>     invoked from within
>>     ("after" script)
>> Moritz
>> -------------------------------------------- Managed by Request Tracker
