[GRASS-dev] Can't create locations using EPSG codes
Patton, Eric
epatton at nrcan.gc.ca
Fri Oct 13 11:37:05 EDT 2006
Maciek,
Thanks for testing this. I wonder what could be causing the problem for me
then? I'm at a complete loss to explain this. I'm using today's cvs. I have
gdal 1.3.2 and the gdal-grass 1.3.1 plugin installed, it that makes any
difference.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: 'grassuser at grass.itc.it'; 'grass-dev at grass.itc.it '
Sent: 10/13/2006 11:21 AM
Subject: Re: [GRASS-dev] Can't create locations using EPSG codes
Patton, Eric wrote:
> Trying to create a new location from the Grass intro screen, using
EPSG code
> 2036 (New Brunswick Double Stereographic)gives the following error:
> child process exited abnormally
> Can anyone reproduce this error for me? I'm using Ubuntu 6.06.
On the same Ubuntu it works for me, uisng 6.3 CVS 2006-10-11. The
location created is:
GRASS 6.3.cvs (test2):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
proj : sterea
a : 6378137
es : 0.006694380022900787
lat_0 : 46.5
lon_0 : -66.5
k : 0.999912
x_0 : 2500000
y_0 : 7500000
towgs84 : 0,0,0,0,0,0,0
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
Maciek
