[GRASS-dev] Tcl/Tk script integration in Grass
thierrygonon
thierrygonon at mac.com
Sun Oct 15 10:24:30 EDT 2006
Hello everybody,
I'm very knew in programming and I'm just trying to add some easy to use
tools for the vector datas in GRASS. My aim ( a command from my
employer) is to make the building of a query (to use after with
v.extract) very easy for people who don't know SQL syntax. For this,
I've first made a simple bash script (that can probably be enhanced)
that works fine. The next point is to provide it trough a GUI, inside
GRASS... I've made a Tcl/Tk script that I've integrated in my GRASS
installation (in
/Applications/grass61cvs.app/Contents/Resources/grass-6.1.cvs/scripts),
and add the line "exec $GRASS_WISH "$0" "$@", but it failed : the answer
is "GRASS_WISH : no such variable". If I don't use the "$0" "$@", a new
wish start, but wait for me to start manually (via file/source) a script...
Can anyone help me ??
Here's my code, it will be easier to talk with it !!
Thierry Gonon
2 place de l'Eglise
01150 LAGNIEU
France
#!/bin/sh
#Version 0.5 (15 octobre 2006)
#Ouverture du script, ouverture ou creation du fichier
set GISDBASE [exec g.gisenv get=GISDBASE]
set LOCATION_NAME [exec g.gisenv get=LOCATION_NAME]
set DB_DRIVER [exec g.gisenv get=DB_DRIVER]
set DB_DATABASE [exec g.gisenv get=DB_DATABASE]
set DB_GROUP [exec g.gisenv get=DB_GROUP]
wm geometry . 800x600
wm title . "fichier de destination"
frame .file -borderwidth 4 -relief sunken
frame .file.s
label .file.int -text "Choix du fichier contenant la requête"
entry .file.file -textvariable filename
button .file.valid -text Valider -command {set idfile [open $GISDBASE/$LOCATION_NAME/$filename.sql w+]}
button .file.s.start -text "Construire la requête" -command {winq .query}
pack .file -side top
pack .file.int .file.file -side left
pack .file.valid -side bottom -expand true
pack .file.s -side left
pack .file.s.start -side bottom
#Création de la fenêtre de saisie de la requête
proc winq {parent} {
global idfile filename w
catch {destroy $parent}
set w [toplevel $parent]
frame $w.cadre -borderwidth 4 -relief sunken
label $w.cadre.fi -text $filename
frame $w.tablechoice -borderwidth 4 -relief sunken
button $w.cadre.exit -text Abandonner -command exit
pack $w.cadre
pack $w.cadre.fi -side left
pack $w.tablechoice -side left
tablechoice
pack $w.cadre.exit -side bottom
#Procédures de création des listes
#Liste des tables disponibles
proc tablelist {} {
global DB_DRIVER DB_DATABASE DB_GROUP
exec {db.tables driver=$DB_DRIVER database=$DB_DATABASE > /tmp/tables}
exec {sed "/^public/!d" /tmp/tables | cut -d'.' -f2 > /tmp/table}
#Liste des colonnes disponibles
proc collist {} {
global DB_DRIVER DB_DATABASE DB_GROUP ::tableselect
exec db.columns driver=$DB_DRIVER database=$DB_DATABASE table=$::tableselect > /tmp/columns
#Liste des valeurs disponibles
proc vallist {} {
global DB_DRIVER DB_DATABASE DB_GROUP ::tableselect ::colselect
exec db.select table=$tableselect driver=pg sql="select $::colselect from $::tableselect" | sed "1d" | sort -u > /tmp/values
#Procédures de sélection
#Sélection de la table à interroger
proc tablechoice {} {
global w
tablelist
set ::tables [split [read [open /tmp/table r]] "\n"]
label $w.tablechoice.int -text "Tables disponibles :"
listbox $w.tablechoice.list -selectmode single -setgrid true -listvariable ::tables
button $w.tablechoice.valid -text Valider -command tablevalid
pack $w.tablechoice.int -side top
pack $w.tablechoice.list -side top -fill x -padx 5
pack $w.tablechoice.valid -side top
#Sélection de la colonne interrogée
proc colchoice {} {
global w
collist
set ::col [split [read [open /tmp/columns r]] "\n"]
label $w.colchoice.int -text "Colonnes disponibles :"
listbox $w.colchoice.list -selectmode single -setgrid true -listvariable ::col
button $w.colchoice.valid -text Valider -command colvalid
pack $w.colchoice
pack $w.colchoice.int -side top
pack $w.colchoice.list -side top -fill x -padx 5
pack $w.colchoice.valid -side top
#Sélection du terme de comparaison
proc relchoice {} {
global w
set ::rel [list < <= = => > différent contient "ne contient pas"]
label $w.relchoice.int -text "Colonnes disponibles :"
listbox $w.relchoice.list -selectmode single -setgrid true -listvariable ::rel
button $w.relchoice.valid -text Valider -command relvalid
pack $w.relchoice
pack $w.relchoice.int -side top
pack $w.relchoice.list -side top -fill x -padx 5
pack $w.relchoice.valid -side top
#Sélection de la valeur de référence
proc valchoice {} {
global w
vallist
set ::val [split [read [open /tmp/values r]] "\n"]
pack $w.valchoice
if {$::val=>20} {
label $w.valchoice.int -text "Valeurs disponibles :"
listbox $w.valchoice.list -selectmode single -setgrid true -listvariable ::val
pack $w.valchoice.int -side top
pack $w.valchoice.list -side top -fill x -padx 5
set ::valselect [$w.valchoice.list curselection]
{label $w.valchoice.int -text "Trop de valeurs. Entrée individuelle."
entry $w.valchoice.val -textvariable ::valselect
pack $w.valchoice.val -side top -fill x -padx 5
button $w.valchoice.valid -text Valider -command valvalid
pack $w.valchoice.valid -side top
#Autre clé de tri ?
proc other {} {
global w
label $w.other.int -text "Voulez-vous ajouter une autre clé de tri ?"
radiobutton $w.other.yes -text "oui" -variable ::otherkey -value 1
radiobutton $w.other.no -text "non" -variable ::otherkey -value 0
button $w.other.valid -text Valider -command othervalid
pack $w.other
pack $w.other.int -side top
pack $w.other.yes -side top -fill x -padx 5
pack $w.other.no -side top -fill x -padx 5
pack $w.other.valid -side top
#Lien entre les clés de tri
proc linq {} {
global w idfile
frame $w.linq -borderwidth 4 -relief sunken
label $w.linq.question "Quel sera le lien avec la clé de tri précédente ?"
radiobutton $w.linq.and -text ET -variable linquery -value AND
radiobutton $w.linq.or -text OU -variable linquery -value OR
pack $w.linq -side top
pack $w.linq.question -side top
pack $w.linq.and $w.linq.or -side right
puts $idfile " "
puts $idfile $linquery
puts $idfile " "
flush $idfile
#Procédures de validation des différents choix
#Validation de la saisie de la table
proc tablevalid {} {
global w idfile ::tables
set tableselect [$w.tablechoice.list curselection]
if {$tableselect!=""} {
set idfile2 [open $GISBASE/$LOCATION_NAME/$filename.table w+]
puts $idfile2 $tableselect
close $idfile2
colchoice
} else {error}
#Validation de la saisie de la colonne
proc colvalid {} {
global w idfile ::col
sel colselect [$w.colchoice.list curselection]
if {$colselect!=""} {
puts $idfile $colselect
puts $idfile " "
flush $idfile
relchoice
} else {error}
#Validation de la saisie du terme de comparaison
proc relvalid {} {
global w idfile ::rel
sel relselect [$w.relchoice.list curselection]
if {$relselect!=""} {
puts $idfile $relselect
puts $idfile " "
flush $idfile
valchoice
} else {error}
#Validation de la saisie de la valeur
proc valvalid {} {
global w idfile ::valselect
if {$valselect!=""} {
puts $idfile "\""
puts $idfile $::valselect
puts $idfile "\""
flush $idfile
other
} else {error}
proc othervalid {} {
global w idfile ::otherkey
if {$::otherkey=1} {
linq
} else {close}
#Erreur en cas de non-sélection
proc error {} {
global w
set y [toplevel $parent]
frame $y.cadre -borderwidth 4 -relief sunken
label $y.cadre.icone -bitmap warning
message $y.cadre.msg -justify left -width 250 -pady 30 -text "Veuillez sélectionner une valeur avant de valider !"
button $y.boutOK -text OK -command {catch {destroy $y}}
pack $y.cadre -side top
pack $y.cadre.icone -side left
pack $y.cadre.msg -side right
pack $y.boutOK -side bottom
#Fermeture de tous les fichiers, suppression des variables...
proc close {} {
global w idfile filename
close $idfile
destroy $w
unset w idfile idfile2 filename ::tableselect ::colselect ::valselect ::tables ::col ::rel ::val ::otherkey
exec {rm /tmp/tables}
exec {rm /tmp/table}
exec {rm /tmp/columns}
exec {rm /tmp/values}
