[GRASS-dev] [bug #5205] (grass) r.colors color=rules: few seconds delay between each warning
Tue Oct 17 07:43:38 EDT 2006
Hamish wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=5205
> > > Subject: r.colors color=rules: few seconds delay between each
> > > warning
> > > If one makes a mistake in rules, resuming from each warning takes
> > > few sec.
> > > eg.
> > > $ r.colors map color=rules
> > > Data range is 0 to 5
> > > > [ENTER]
> > > WARNING: bad color specification
> > > [few seconds]
> > > WARNING: rule is not added
> > > [few seconds]
> > The delay is built into lib/gis/error.c; it should be removed, IMHO.
> the delay is there for interactive modules which clear the screen; if
> there is no delay there is no chance to see the warning before the
> terminal blanks and know that something is wrong.
> these modules call:
>   G_sleep_on_error(1);
> the default is:
>   G_sleep_on_error(0);
> the problem with r.colors is that raster/r.colors/main.c explicitly
> calls G_sleep_on_error(1);
I have removed the G_sleep_on_error() calls.
