[GRASS-dev] d.vect -a shows only some elements
Moritz Lennert mlennert at club.worldonline.be
Thu Oct 12 11:36:21 EDT 2006
Using d.vect.thematic -u I fill a grassrgb column in the attribute
table. See http://moritz.homelinux.org/grass/d_vect_a1.png.
But when I try to reuse these colors with d.vect -a, only a few of the
regions get filled (with an additional dissolution of common
boundaries): http://moritz.homelinux.org/grass/d_vect_a2.png
All of the objects in the map have a color code in the grassrgb column.
I cannot reproduce this problem in spearfish, so I am a bit lost.
Any ideas ?
Moritz
