[GRASS-dev] GISDBASE directory name with spaces
    Moritz Lennert
    mlennert at club.worldonline.be
    Wed Oct 18 05:37:23 EDT 2006
Hello,
Trying to help some colleagues working with wingrass, I noticed that if
the GISDBASE variable in .grassrc6 containes spaces (ex: GISDBASE:
/home/mlennert/GRASS/TEST DATA), the gui startup screen does not
recognize the directory and gives a warning: "Invalid database. Finding
first valid directory in parent tree". However, I can manually navigate
to the directory and GRASS starts normally.
As many MS Windows users have spaces in their directory names, I
personally think that the startup screen code should be fixed to allow
spaces in the GISDBASE variable. I imagine it probably is a "simple"
issue of quoting in line 64 of lib/init/gis_set.tcl:
63: if { [scan $thisline "GISDBASE: %s" env_database] } {
64:       set database $env_database
but I don't know enough tcl to do this.
Moritz
