[GRASS-dev] [bug #5218] (grass) wingrass: creating new location from startup screen with projection values fails
Michael Barton michael.barton at asu.edu
Wed Oct 18 12:42:07 EDT 2006
This won't work because it requires an interactive xterm. This is not
currently available in wingrass, though I think I remember some discussion
by Glynn suggesting that it might (or might not) be possible to compile
wingrass in such a way as to make this and similar functions work.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Wed, 18 Oct 2006 11:13:18 +0200 (CEST)
> To: <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] [bug #5218] (grass) wingrass: creating new location from
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5218
> Subject: wingrass: creating new location from startup screen with projection
> values fails
> Platform: WindowsNT/2000/XP
> grass obtained from: Other (CDROM etc)
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: huidae's wingrass version sept. 17
> Trying to create a new location from the startup screen in wingrass entering
> projection values manually doesn't work. The procedure crashes after entering
> the one-line description of the new location with an error message: "the
> syntax of the command is not correct. LOCATION (test) NOT created" (translated
> from French).
> Just before that, after the confirmation of the coordinate system choice there
> is a message: "'clear' is not recognized as an internal command" (translated
> from French).
> Moritz
> -------------------------------------------- Managed by Request Tracker
