[GRASS-dev] [bug #5218] (grass) wingrass: creating new location from startup screen with projection values fails
Request Tracker grass-bugs at intevation.de
Wed Oct 18 05:13:18 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5218
Subject: wingrass: creating new location from startup screen with projection values fails
Platform: WindowsNT/2000/XP
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: huidae's wingrass version sept. 17
Trying to create a new location from the startup screen in wingrass entering projection values manually doesn't work. The procedure crashes after entering the one-line description of the new location with an error message: "the syntax of the command is not correct. LOCATION (test) NOT created" (translated from French).
Just before that, after the confirmation of the coordinate system choice there is a message: "'clear' is not recognized as an internal command" (translated from French).
Moritz
-------------------------------------------- Managed by Request Tracker
