[GRASS-dev] [bug #5217] (grass) wingrass: creating new
location from startup screen fails with georeferenced file
Moritz Lennert
mlennert at club.worldonline.be
Thu Oct 19 04:22:12 EDT 2006
On Wed, October 18, 2006 11:07, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=5217
> Subject: wingrass: creating new location from startup screen fails with
> georeferenced file
> Platform: WindowsNT/2000/XP
> grass obtained from: Other (CDROM etc)
> grass binary for platform: Downloaded precompiled Binaries
> GRASS Version: huidae's wingrass version sept. 17
> Trying to create a new location from the startup screen in wingrass using
> a georeferenced file gives the following error:
> channel "console2" wasn't opened for writing
> while executing
> "exec -- g.proj -c georef=$filepath location=$fileLocation >@stdout
> 2>@stderr"
> invoked from within
> ".fileloc.def invoke"
> ("uplevel" body line 1)
> invoked from within
> "uplevel #0 [list $w invoke]"
> (procedure "tk::ButtonUp" line 24)
> invoked from within
> "tk::ButtonUp .fileloc.def
> (command bound to event)
I do not get this error if I start grass from a msys terminal, instead of
using grass.bat.
Any reason to use cmd.exe as terminal, instead of the msys terminal ?
Moritz
