[GRASS-dev] Re: grass-dev Digest, Vol 6, Issue 50
Michael Barton
michael.barton at asu.edu
Wed Oct 18 12:59:16 EDT 2006
In the script, the expression parser seems to have been implemented.
However, it is broken on my Mac and doesn't produce any results. It may be
due to issues with the database modules that will be resolved when I have
time to update, but I wonder if anyone else has had problems recently.
It (and v.univar.sh) also use "which awk" to check for the presence of awk.
This also fails on my Mac, running bash.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: <grass-dev-request at grass.itc.it>
> Reply-To: <grass-dev at grass.itc.it>
> Date: Wed, 18 Oct 2006 17:02:28 +0200
> Subject: grass-dev Digest, Vol 6, Issue 50
> Send grass-dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://grass.itc.it/mailman/listinfo/grass-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass-dev-owner at grass.itc.it
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-dev digest..."
> Today's Topics:
> 1. [bug #4436] (grass) implement expression parser for
> d.vect.thematic (Maciek Sieczka via RT)
> 2. [bug #5097] (grass) d.vect.chart: add where option
> 3. [bug #5219] (grass) d.vect display=cat works only for layer 1
> (Request Tracker)
> 4. Re: making r.out.gdal region sensitive (Glynn Clements)
> 5. Re: GISDBASE directory name with spaces (Glynn Clements)
> 6. Re: [bug #5097] (grass) d.vect.chart: add where option
> (Moritz Lennert)
> 7. Re: [bug #4436] (grass) implement expression parser for
> d.vect.thematic (Moritz Lennert)
> 8. libgrass_gmath.so: cannot restore segment+Permission denied
> (madhu)
> 9. g.list type=rast gives floating point exception (Patton, Eric)
> 10. Re: GISDBASE directory name with spaces (Moritz Lennert)
> 11. r.resamp.stats documentation? (Markus Neteler)
> 12. RE: g.list type=rast gives floating point exception (Patton, Eric)
> 13. RE: [GRASS-user] g.list type=rast gives floating point
