[GRASS-dev] r.in.xyz: *** glibc detected *** double free or corruption
Patton, Eric epatton at nrcan.gc.ca
Fri Oct 20 16:29:05 EDT 2006
Although I seem to now be able to *open* large files with r.in.xyz, it
inevitably crash about 15 minutes into the gridding of a 2.8GB xyz file,
every time.
Here's the output from gdb:
(gdb) r.in.xyz input=2006MB_GarryTrough_2.txt output=2006MB_GarryTrough_2
fs=space
Starting program: /opt/grass6/dist.i686-pc-linux-gnu/bin/r.in.xyz .in.xyz
input=2006MB_GarryTrough_2.txt output=2006MB_GarryTrough_2 fs=space
Scanning data ...
*** glibc detected *** double free or corruption (fasttop): 0x0804e2c8 ***
Program received signal SIGABRT, Aborted.
0xffffe410 in __kernel_vsyscall ()
(gdb) bt
#0  0xffffe410 in __kernel_vsyscall ()
#1  0xb7d959a1 in raise () from /lib/tls/i686/cmov/libc.so.6
#2  0xb7d972b9 in abort () from /lib/tls/i686/cmov/libc.so.6
#3  0xb7dc987a in __fsetlocking () from /lib/tls/i686/cmov/libc.so.6
#4  0xb7dcffd4 in malloc_usable_size () from /lib/tls/i686/cmov/libc.so.6
#5  0xb7dd034a in free () from /lib/tls/i686/cmov/libc.so.6
#6  0xb7f0293a in G_free (buf=0x0) at alloc.c:104
#7  0xb7f2eb03 in G_free_tokens (tokens=0x4b) at token.c:68
#8  0x0804a706 in main (argc=0, argv=0xbf952fa4) at main.c:468
(gdb)
I may need some pointers on using gdb, as this is my first time. But
hopefully this backtrace will be useful.
~ Eric.
