[GRASS-dev] Re: [GRASS-user] r.in.xyz: *** glibc detected *** double free or corruption
Fri Oct 20 19:10:23 EDT 2006
Patton, Eric wrote:
> Although I seem to now be able to *open* large files with r.in.xyz, it
> inevitably crash about 15 minutes into the gridding of a 2.8GB xyz file,
> every time.
> Here's the output from gdb:
> (gdb) r.in.xyz input=2006MB_GarryTrough_2.txt output=2006MB_GarryTrough_2
> fs=space
> Starting program: /opt/grass6/dist.i686-pc-linux-gnu/bin/r.in.xyz .in.xyz
> input=2006MB_GarryTrough_2.txt output=2006MB_GarryTrough_2 fs=space
> Scanning data ...
> *** glibc detected *** double free or corruption (fasttop): 0x0804e2c8 ***
> Program received signal SIGABRT, Aborted.
> 0xffffe410 in __kernel_vsyscall ()
> (gdb) bt
> #0  0xffffe410 in __kernel_vsyscall ()
> #1  0xb7d959a1 in raise () from /lib/tls/i686/cmov/libc.so.6
> #2  0xb7d972b9 in abort () from /lib/tls/i686/cmov/libc.so.6
> #3  0xb7dc987a in __fsetlocking () from /lib/tls/i686/cmov/libc.so.6
> #4  0xb7dcffd4 in malloc_usable_size () from /lib/tls/i686/cmov/libc.so.6
> #5  0xb7dd034a in free () from /lib/tls/i686/cmov/libc.so.6
> #6  0xb7f0293a in G_free (buf=0x0) at alloc.c:104
> #7  0xb7f2eb03 in G_free_tokens (tokens=0x4b) at token.c:68
> #8  0x0804a706 in main (argc=0, argv=0xbf952fa4) at main.c:468
> (gdb)
> I may need some pointers on using gdb, as this is my first time. But
> hopefully this backtrace will be useful.
Not really. This is heap corruption; the backtrace corresponds to the
point where the corruption was detected, which is usually long after
the corruption actually occurred.
The usual mechanisms for dealing with heap corruption are:
1. Manually examine the code for errors (alloc/free mismatches,
potential out-of-bounds array writes).
2. Use heap checking tools (libmcheck, Electric Fence, valgrind).
Using option #1, the following is noticable (line 467+):
		else { /* oh well, we tried. */
		    G_free_tokens(tokens);
		    continue;
The tokens array has already been freed at line 447, so this call is
bogus; remove the G_free_tokens() call, resulting in:
		    continue;
