[GRASS-dev] pj_transform problem: failed to load NAD27-83 correction file
Sun Oct 22 23:57:04 EDT 2006
Yann Chemin wrote:
> > > I am trying to make a program writing a latitude map.
> it simply fills up the pixels with Latitude values.
> http://www.star.ait.ac.th/~yann/sebal/r.latitude.tar.gz
Here is how to do it in a shell script, using r.stats, m.proj, and
r.in.xyz. (slower than a C version, but uses just standard grass modules
and unix tools)
r.stats -1gn fields | cut -f1,2 -d' ' > fields_coord.txt
# datum will be WGS84!! use "proj_out=" if you want another datum
m.proj -od < fields_coord.txt | awk '{print $2}' > lat_values.txt
paste -d' ' fields_coord.txt lat_values.txt > fields_lat_coord.txt
r.in.xyz in=fields_lat_coord.txt fs=space out=fields_lat
\rm fields_coord.txt lat_values.txt fields_lat_coord.txt
another idea is to add lat() and lon() as r.mapcalc internal variables,
just like x() and y(). But you must deal with the "which datum to use?"
problem.
Hamish
