[GRASS-dev] pj_transform problem: failed to load NAD27-83
correction file
Yann Chemin
ychemin at gmail.com
Thu Oct 19 19:15:14 EDT 2006
Here is the code:
it simply fills up the pixels with Latitude values.
http://www.star.ait.ac.th/~yann/sebal/r.latitude.tar.gz
You may run it on any raster (i.e. elevation.10m) in Spearfish and it
will return that error.
thanks
yann
On 20/10/06, Paul Kelly <paul-grass at stjohnspoint.co.uk> wrote:
> On Fri, 13 Oct 2006, Yann Chemin wrote:
> > Hi list,
> > I am trying to make a program writing a latitude map. it works in a
> > lat/lon projection, but the only non-ll mapset i have is Spearfish,
> > and when testing on it, it returned this:
> What exactly are you doing to test it (areas covered by locations, command
> line used etc.)? Are you sure the data you're trying to project falls
> within the area covered by the conus datum transformation grid used in
> Spearfish? PROJ emits that same error message for a rather large variety
> of different error conditions so it's hard to know exactly what's going
> on.
> > pj_transform() failed
> > cause: failed to load NAD27-83 correction file
> > GRASS_INFO_ERROR(19542,1): Error in pj_do_proj
> > How can i get through this problem? is it a problem in compilation of proj?
> > thanks,
> > Yann
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
Some Google Working rules:
* Developers can switch teams and/or projects any time they want, no
questions asked; just say the word and the movers will show up the
next day to put you in your new office with your new team.
* There aren't very many meetings. I'd say an average developer
attends perhaps 3 meetings a week.
* Google has a philosophy of not ever telling developers what to work
on, and they take it pretty seriously.
* Google tends not to pre-announce. They really do understand that you
can't rush good cooking, you can't rush babies out, and you can't rush
software development.
