[GRASS-dev] pj_transform problem: failed to load NAD27-83
correction file
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Oct 19 18:14:26 EDT 2006
On Fri, 13 Oct 2006, Yann Chemin wrote:
> Hi list,
> I am trying to make a program writing a latitude map. it works in a
> lat/lon projection, but the only non-ll mapset i have is Spearfish,
> and when testing on it, it returned this:
What exactly are you doing to test it (areas covered by locations, command
line used etc.)? Are you sure the data you're trying to project falls
within the area covered by the conus datum transformation grid used in
Spearfish? PROJ emits that same error message for a rather large variety
of different error conditions so it's hard to know exactly what's going
on.
> pj_transform() failed
> cause: failed to load NAD27-83 correction file
> GRASS_INFO_ERROR(19542,1): Error in pj_do_proj
> How can i get through this problem? is it a problem in compilation of proj?
> thanks,
> Yann
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
