[GRASS-dev] d.vect -a shows only some elements
Martin Landa
landa.martin at gmail.com
Mon Oct 23 11:13:58 EDT 2006
Hi Moritz,
2006/10/23, Moritz Lennert <mlennert at club.worldonline.be>:
> Martin Landa wrote:
> > Hi,
> > 2006/10/21, Moritz Lennert <mlennert at club.worldonline.be>:
> > [snip]
> >> > you are right (if I understand well), adding
> >> > db_CatValArray_sort (&cvarr_rgb);
> >> > should solve the problem. I wonder why db_select_CatValArray sorts
> >> > cvarr->value by category number only for data type int or double...
> >> > (?), see
> >> > 00300 if ( type == DB_C_TYPE_INT )
> >> > 00301 qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
> >> > cmpcat);
> >> > 00302 else if ( type == DB_C_TYPE_DOUBLE )
> >> > 00303 qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
> >> > cmpcat);
> >> Applying below patch directly to db_select_CatValArray solves the problem
> >> for me, but I don't know if this might cause other problems, even
> >> though I
> >> doubt it.
> >> Any ideas ?
> >> Moritz
> >> Index: lib/db/dbmi_client/select.c
> >> RCS file: /grassrepository/grass6/lib/db/dbmi_client/select.c,v
> >> retrieving revision 1.8
> >> diff -u -r1.8 select.c
> >> --- lib/db/dbmi_client/select.c 14 Jul 2006 16:41:22 -0000 1.8
> >> +++ lib/db/dbmi_client/select.c 20 Oct 2006 23:22:26 -0000
> >> @@ -297,10 +297,7 @@
> >> db_close_cursor(&cursor);
> >> db_free_string ( &stmt );
> >> - if ( type == DB_C_TYPE_INT )
> >> - qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal), cmpcat);
> >> - else if ( type == DB_C_TYPE_DOUBLE )
> >> + db_CatValArray_sort ( cvarr );
> >> return (nrows);
> > in this case the array is sorted twice for datatype DB_C_TYPE_INT and
> > DB_C_TYPE_DOUBLE, I suggest
> > RCS file: /home/grass/grassrepository/grass6/lib/db/dbmi_client/select.c,v
> > +++ lib/db/dbmi_client/select.c 21 Oct 2006 07:43:35 -0000
> > @@ -297,9 +297,8 @@
> > + if ( type == DB_C_TYPE_INT || type == DB_C_TYPE_DOUBLE ||
> > + type == DB_C_TYPE_STRING )
> > return (nrows);
> > Not sure if you need to check "type" here (what about DB_C_TYPE_DATETIME)??
> Don't know, either. The whole idea is to have the array sorted by cat
> when it is returned. No reason that this should be any different
> whatever the datatype of the attached data column.
> This is why I suggested replacing the whole thing by one simple call to
> where db_CatValArray_sort simply contains:
> qsort( (void *) arr->value, arr->n_values, sizeof(dbCatVal), cmpcat);
> i.e. exactly the same sorting call.
Personally I agree with you. I don't think you have to check data type
of CatVal.value[].val for sorting of CatValArray array by cat.
> So, why would that sort the array twice ?
Sorry!, it was mistake. Please forget it:-)
> Moritz
Best, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
