[GRASS-dev] d.vect -a shows only some elements
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 23 12:04:26 EDT 2006
Martin Landa wrote:
> Hi Moritz,
> 2006/10/23, Moritz Lennert <mlennert at club.worldonline.be>:
>> Martin Landa wrote:
>> > Hi,
>> > 2006/10/21, Moritz Lennert <mlennert at club.worldonline.be>:
>> > [snip]
>> >> > you are right (if I understand well), adding
>> >> > db_CatValArray_sort (&cvarr_rgb);
>> >> > should solve the problem. I wonder why db_select_CatValArray sorts
>> >> > cvarr->value by category number only for data type int or double...
>> >> > (?), see
>> >> > 00300     if ( type == DB_C_TYPE_INT )
>> >> > 00301         qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
>> >> > cmpcat);
>> >> > 00302     else if ( type == DB_C_TYPE_DOUBLE )
>> >> > 00303         qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
>> >> > cmpcat);
>> >> Applying below patch directly to db_select_CatValArray solves the
>> problem
>> >> for me, but I don't know if this might cause other problems, even
>> >> though I
>> >> doubt it.
>> >> Any ideas ?
>> >> Moritz
>> >> Index: lib/db/dbmi_client/select.c
>> >> RCS file: /grassrepository/grass6/lib/db/dbmi_client/select.c,v
>> >> retrieving revision 1.8
>> >> diff -u -r1.8 select.c
>> >> --- lib/db/dbmi_client/select.c 14 Jul 2006 16:41:22 -0000      1.8
>> >> +++ lib/db/dbmi_client/select.c 20 Oct 2006 23:22:26 -0000
>> >> @@ -297,10 +297,7 @@
>> >>      db_close_cursor(&cursor);
>> >>      db_free_string ( &stmt );
>> >> -    if ( type == DB_C_TYPE_INT )
>> >> -        qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal),
>> cmpcat);
>> >> -    else if ( type == DB_C_TYPE_DOUBLE )
>> cmpcat);
>> >> +    db_CatValArray_sort ( cvarr );
>> >>      return (nrows);
>> > in this case the array is sorted twice for datatype DB_C_TYPE_INT and
>> > DB_C_TYPE_DOUBLE, I suggest
>> > RCS file:
>> /home/grass/grassrepository/grass6/lib/db/dbmi_client/select.c,v
>> > +++ lib/db/dbmi_client/select.c    21 Oct 2006 07:43:35 -0000
>> > @@ -297,9 +297,8 @@
>> cmpcat);
>> > +    if ( type == DB_C_TYPE_INT || type == DB_C_TYPE_DOUBLE ||
>> > +     type == DB_C_TYPE_STRING )
>> >         qsort( (void *) cvarr->value, nrows, sizeof(dbCatVal), cmpcat);
>> >     return (nrows);
>> > Not sure if you need to check "type" here (what about
>> DB_C_TYPE_DATETIME)??
>> Don't know, either. The whole idea is to have the array sorted by cat
>> when it is returned. No reason that this should be any different
>> whatever the datatype of the attached data column.
>> This is why I suggested replacing the whole thing by one simple call to
>> where db_CatValArray_sort simply contains:
>>   qsort( (void *) arr->value, arr->n_values, sizeof(dbCatVal), cmpcat);
>> i.e. exactly the same sorting call.
> Personally I agree with you. I don't think you have to check data type
> of CatVal.value[].val for sorting of CatValArray array by cat.
>> So, why would that sort the array twice ?
> Sorry!, it was mistake. Please forget it:-)
Ok, have just committed my above proposal.
Thanks for the help !
Moritz
