[GRASS-dev] Tk implemantation of a query function
Thierry Gonon thierrygonon at mac.com
Mon Oct 23 11:27:58 EDT 2006
Hi everybody,
I'm a beginner in programmation and my goal (as wanted by my boss) is to add a function to make the building of a query easier and more friendly that it is actually (so that people who don't know SQL syntax can build queries !!).
I've made a first script in bash, that works quite well (for postgres, but I'm planning to extend it to other databases used by GRASS). And now, Im'trying to make it more friendly, thru Tk. My problem is the following error :
Error in startup script: can't read "GRASS_WISH": no such variable
    while executing
"exec $GRASS_WISH "$0" "$@""
If I only write "exec $GRASS_WISH" in this line, the error is that it opens a new window and freeze everything...
I think my problems are very small... But can someone helps me ??
I join my code to help !
Thanks
Thierry Gonon
2 Place de l'Eglise
01150 LAGNIEU
Tél : 04 74 34 49 26
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061023/08e7618a/db_q_e.obj
