[GRASS-dev] [bug #5200] (grass) d.what.vect: WARNING: Color: can't set color 50331648
Maciek Sieczka via RT grass-bugs at intevation.de
Mon Oct 23 15:28:24 EDT 2006
guest wrote (Wed, Oct 11 2006 12:30:55):
> Any query with d.what.vect in GUI mode results in:
I forgot to add that the WARNING is printed to terminal.
The exact to reproduce this is:
1. d.m
2. display a vector
3. press ? icon in d.m
4. query - you will get the expected output in the tcl/tk window and a
"WARNING: Color: can't set color 50331648" in the terminal
BTW, do we need "Done." message in d.what.vect? d.what.rast doesn't print it...
Maciek
-------------------------------------------- Managed by Request Tracker
