[GRASS-dev] [bug #5200] (grass) d.what.vect: WARNING: Color: can't set color 50331648
Tue Oct 24 00:22:40 EDT 2006
Maciek Sieczka via RT wrote:
> guest wrote (Wed, Oct 11 2006 12:30:55):
> > Any query with d.what.vect in GUI mode results in:
> I forgot to add that the WARNING is printed to terminal.
> The exact to reproduce this is:
> 1. d.m
> 2. display a vector
> 3. press ? icon in d.m
> 4. query - you will get the expected output in the tcl/tk window and a
> "WARNING: Color: can't set color 50331648" in the terminal
works for me.
6.3-cvs, d.m + spearfish60 fields (no centroids, rand colors) map, roads
map.
> BTW, do we need "Done." message in d.what.vect? d.what.rast doesn't
> print it...
It's there so when called from d.m, in the terminal window the last text
changes from:
Buttons
 Left:  what's here
 Middle: toggle flash color
 Right: quit
otherwise someone might think they can still click after they've right
clicked.
middle click to change flash color doesn't seem to work for me (?)
Also it doesn't flash if you click where an undisplayed centroid is.
Hamish
