[GRASS-dev] Re: [GRASS-CVS] maciej: grass6/general/g.findfile description.html, 1.4, 1.5
Markus Neteler neteler at itc.it
Mon Oct 23 15:28:47 EDT 2006
On Mon, Oct 23, 2006 at 09:17:58PM +0200, grass at intevation.de wrote:
> RCS file: /grassrepository/grass6/general/g.findfile/description.html,v
> +However, you can find a list of standard GRASS <em>element</em> names in the
> +file $GISBASE/etc/element_list. This is the file which g.remove/g.rename/g.copy
> +use to determine which files need to be deleted/renamed/copied for a given
> +entity type.
a style question: Up to now most GRASS documentation (HTML/MAN pages)
say "the user", here "you" was introduced.
Maybe it's a non-issue, but I feel that it the style of writing should
be decided and homogeneous.
Opinions?
Markus
