[GRASS-dev] r.out.gdal rewritten
Hamish
hamish_nospam at yahoo.com
Wed Oct 25 01:21:32 EDT 2006
> Hamish wrote:
> > > format->options =
> > > "AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MF
> > > F2, NITF,PAux,PNG,PNM,VRT,XPM";
> > don't hardcode the available formats. They will depend on the local
> > installation of GDAL, and what configure flags it was built with,
> > and as such options will vary widely. If you hard code it you impose
> > an artificial barrier to optional and future raster formats.
> > depend on "r.out.gdal -l" and examples (GTiff) instead.
Vytautas wrote:
> List of avaible formats in format options is now generated dynamicly.
G_gisinit (argv[0]);
+ /* Init GDAL */
+ GDALAllRegister();
module = G_define_module();
+ supported_formats(&gdal_formats);
format = G_define_option();
format->key = "format";
format->type = TYPE_STRING;
format->description = _("GIS format to write (case sensitive, see also -l flag)");
- format->options = "AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF2,N
+ /* format->options = "AAIGrid,BMP,BSB,DTED,ELAS,ENVI,FIT,GIF,GTiff,HFA,JPEG,MEM,MFF,MFF
2,NITF,PAux,PNG,PNM,VRT,XPM"; */
+ if (gdal_formats)
+ format->options = G_store (gdal_formats);
+ else
+ G_fatal_error (_("Unknown GIS formats"));
format->answer = "GTiff";
format->required = NO;
if (G_parser(argc,argv)) exit(EXIT_FAILURE);
it is bad to put any non parser code before G_parser():
http://article.gmane.org/gmane.comp.gis.grass.devel/12473/
http://article.gmane.org/gmane.comp.gis.grass.devel/5224
http://article.gmane.org/gmane.comp.gis.grass.devel/12446/
http://article.gmane.org/gmane.comp.gis.grass.devel/7169
Hamish
