[GRASS-dev] RE: [bug #3112] r.watershed hangs
Charles Ehlschlaeger
c.ehlschlaeger at insightbb.com
Wed Oct 25 17:35:16 EDT 2006
Dear Hamish,
Thanks for posting the patch of r.watershed. That snippet of code ensures
that colors allocated to watersheds are as different as possible. Back in
the early '90s, we were so worried about RAM use that we wrote convoluted
code that prevented making new arrays whenever possible.
The simpliest fix would be to insert a conditional after
G_make_random_colors(&colors, 1, max) as shown in the patch below (two lines
added). From a visualization perspective, 1000 basins are too many basins to
matter anyway, so 1000 might be good. If you look at the experiment you
performed, you can see 10000 basins took 3 minutes to run.
The best fix would be to write an algorithm that chooses category color
based on adjacent cell values. Here is a psuedo code solution:
random_colors( Raster map, Color[] colors) {
long adjacentColors[][] = new long[ colors.length][];
for( int r = 0; r < map.rows(); r++) {
for( int c = 0; c < map.cols(); c++) {
long cellValue = map.getValue( r, c);
if( c < map.cols() - 1) {
if( map.getValue( r, c + 1) < cellValue) {
// add map.getValue( r, c + 1) to adjacentColors[
cellValue][] if not already in array
if( r < map.rows() - 1) {
if( map.getValue( r + 1, c ) < cellValue) {
// add map.getValue( r + 1, c) to adjacentColors[
if( (r < map.rows() - 1) && c < map.cols() - 1) {
if( map.getValue( r + 1, c + 1 ) < cellValue) {
// add map.getValue( r + 1, c + 1) to adjacentColors[
for( int i = 0; i < colors.length; i++) {
// if no adjacentColors[i] == null, give any random color
// otherwise randomly create 100 colors
// choose color furthest from colors of adjacentColors[i] array
Sincerely, chuck
-----Original Message-----
Sent: Wednesday, October 25, 2006 3:01 AM
To: grass5
Cc: hardeep at eml.cc; grass-bugs at intevation.de; c.ehlschlaeger at insightbb.com
Subject: Re: [bug #3112] r.watershed hangs
Hardeep Singh Rai wrote:
> I was doing watershed analysis for spearfish dataset
> (spearfish_grass60data-0.1.tar.gz), and on giving command:
> r.watershed elevation=elevation.dem threshhold=3 basin=raiBasin
> accumulation=raiAccu it starts processing of 5 steps. After about 20
> minutes, it completes all and throw message: "cloing maps", but do
> nothing; prompt never comes. I used it with option -m and without it.
> With both cases, "top" commands show ram or sed running with 99 usage
> of CPU. Even I waited for 12 hours, but it fail to finish. I am using
> GRASS 6.0.1 on Ubuntu.
> Please suggest some solution.
Hamish wrote:
> It's a known bug (#3112). It gets stuck trying to make a huge set of
> colormap rules for the new map. If you cancel (^C) you might find the
> map was created anyway (???).
Chuck wrote:
> The solution is to include a more realistic threshold size.
Yes.
The attached patch shows the problem quite well. As the treshold gets
smaller, the number of areas (cats) grows exponentially. Not only that,
but as the loop within a loop runs, it takes longer and longer to do the
same thing.
The inner loop gets slower I think due to the increased number of color
rules set with G_set_color() that have to be read each time.
#spearfish
g.region rast=elevation.dem
r.watershed elev=elevation.dem basin=tmp_basin thresh=200
d.rast tmp_basin
thresh=200 # 1488 cats
real 0m38.558s
user 0m37.770s
sys 0m0.110s
thresh=100 # 2858 cats
real 0m41.296s
user 0m41.050s
sys 0m0.120s
thresh=50 # 5482 cats
real 0m57.495s
user 0m55.870s
sys 0m0.180s
thresh=37 # 7258 cats
real 1m20.985s
user 1m20.340s
sys 0m0.200s
thresh=25 # 10648 cats
real 3m5.185s
user 3m4.020s
sys 0m0.280s
there are a lot of loops here, but I think the main problem is with so
many calls to G_{get,set}_color():
raster/r.watershed/ram/close_maps2.c
G_init_colors(&colors);
G_make_random_colors(&colors, 1, max);
// new code next line
if( max < 10000) {
G_set_color((CELL)0, 0, 0, 0, &colors);
r = 1;
incr = 0;
while(incr >= 0) {
for (gr=130+incr; gr<=255; gr += 20) {
for (rd=90+incr; rd<=255; rd += 30) {
for (bl=90+incr; bl<=255; bl += 40) {
flag = 1;
while (flag) {
G_get_color(r,&red,&green,&blue, &colors);
if((blue*.11 + red*.30 + green*.59) < 100) {
G_set_color(r, rd, gr, bl, &colors);
flag = 0;
if (++r > max) {
gr = rd = bl = 300;
flag = 0;
incr = -1;
if (incr >= 0) {
incr += 15;
if (incr > 120)
incr = 7;
}// new code next line
Hamish
