[GRASS-dev] Re: [bug #3112] r.watershed hangs
Hamish
hamish_nospam at yahoo.com
Thu Oct 26 01:59:37 EDT 2006
Charles Ehlschlaeger wrote:
> Thanks for posting the patch of r.watershed. That snippet of code
> ensures that colors allocated to watersheds are as different as
> possible. Back in the early '90s, we were so worried about RAM use
> that we wrote convoluted code that prevented making new arrays
> whenever possible.
IMO this is why GRASS has (in general) scaled so well for today's
massive datasets. Raster overheads are very low.
> The simpliest fix would be to insert a conditional after
> G_make_random_colors(&colors, 1, max) as shown in the patch below (two
> lines added).
thanks, applied to the 6.2 & 6.3(HEAD) branches.
Also took the opportunity to slop on lots of metadata in the output
maps (6.3cvs only).
> From a visualization perspective, 1000 basins are too
> many basins to matter anyway, so 1000 might be good. If you look at
> the experiment you performed, you can see 10000 basins took 3 minutes
> to run.
I went with 10000.
> The best fix would be to write an algorithm that chooses category
> color based on adjacent cell values. Here is a psuedo code solution:
> random_colors( Raster map, Color[] colors) {
> long adjacentColors[][] = new long[ colors.length][];
> for( int r = 0; r < map.rows(); r++) {
> for( int c = 0; c < map.cols(); c++) {
> long cellValue = map.getValue( r, c);
> if( c < map.cols() - 1) {
> if( map.getValue( r, c + 1) < cellValue) {
> // add map.getValue( r, c + 1) to adjacentColors[
> cellValue][] if not already in array
> if( r < map.rows() - 1) {
> if( map.getValue( r + 1, c ) < cellValue) {
> // add map.getValue( r + 1, c) to adjacentColors[
> if( (r < map.rows() - 1) && c < map.cols() - 1) {
> if( map.getValue( r + 1, c + 1 ) < cellValue) {
> // add map.getValue( r + 1, c + 1) to adjacentColors[
> for( int i = 0; i < colors.length; i++) {
> // if no adjacentColors[i] == null, give any random color
> // otherwise randomly create 100 colors
> // choose color furthest from colors of adjacentColors[i] array
The random case doesn't do too poorly. (256^3 color possibilities vs.
the four-color theorem)
color distance in 3D RGB space isn't something I understand how to do
well. (I've wondered for a while how to find the "opposite" RGB color:
think of it as a vector ray from the origin inside a 3D sphere?)
Anyway, I'll have to leave the "better way" for someone who understands
color-space a bit better than I do.
thanks,
Hamish
