[GRASS-dev] gis.m broken in 6.2.0rc3 for Tcl/Tk 8.3
Michael Barton michael.barton at asu.edu
Thu Oct 26 09:40:58 EDT 2006
Hi Hamish,
Out of town, but did have a chance to look at mail this morning. This is the
kind of issue that was afraid of earlier. I appreciate you taking the time
to test this, however.
-compound can be deleted because it is turned off anyway
The -offrelief and -overrelief make the radio buttons in the tool bar look
consistent with the non-radio buttons. In this sense they are cosmetic.
However, the enormous part of the TclTk code is 'cosmetic' in that it gives
a particular appearance to the user interface.
IMHO, taking out these commands will degrade the presentation of the GUI
somewhat in a very heavily used area (as opposed to the digitizing panel in
the earlier issue). Is this worth making the GUI compatible with TclTk 8.3?
I'm not sure. If this is a significant issue and the only one that keeps
GRASS from being available to a large segment of the user community, it
probably is worth it. If it is something that affects a few people who could
update their TclTk if they wanted to do so, then I think it is not.
The same kind of issue is already popping up with wxPython.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Thu, 26 Oct 2006 22:01:20 +1300
> To: grass5 <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] gis.m broken in 6.2.0rc3 for Tcl/Tk 8.3
> Hi,
> As the subject says, gis.m is fully broken in 6.2 for Tcl/Tk's wish8.3,
> as -offrelief, -overrelief, and -compound are unknown to it.
> If I remove all those, it works fine. The only difference I see is that
> without the extra relief calls the mouse-mode (pointer,zoom,pan) buttons
> have some shaddowing. This is arguably wanted, as they are select-one
> radio buttons. Pretty minor thing though.
> I expect -offrelief and -overrelief are just cosmetic, so they can be
> removed without worry; and AFAICT, -compound isn't actually doing
> anything as the zoom menu items don't have associated icons. (???)
> These were introduced way back in May, I've just noticed now as while
> I've been switching tcltk 8.3 & 8.4 -dev packages, I've kept using
> wish8.4. .. just tried building 6.2rc3 on another machine which is
> pure tcltk 8.3 & this popped up.
> comments?
> Hamish
> G:grass-6.2.0RC3 > gis.m
> G:grass-6.2.0RC3 > Error in startup script: unknown option "-offrelief"
>     while executing
> "radiobutton $tb.pointer  -image [image create photo -file
> "$iconpath/gui-pointer.gif"]  -command "MapCanvas::stoptool $mon;
> MapCanvas::poin
> ter $mon"  ..."
>     (procedure "MapToolBar::create" line 36)
>     invoked from within
> "MapToolBar::create $map_tb"
>     (procedure "MapCanvas::create" line 51)
>     invoked from within
> "MapCanvas::create"
>     (procedure "Gm::startmon" line 11)
>     invoked from within
> "Gm::startmon"
>     (procedure "Gm::create" line 69)
>     invoked from within
> "Gm::create"
>     (procedure "main" line 30)
>     invoked from within
> "main $argc $argv"
>     (file
> "/usr/src/grass/grass-6.2.0RC3/dist.i686-pc-linux-gnu/etc/gm/gm.tcl"
> line 521)
> G:grass-6.2.0RC3 > cd gui/tcltk/
> G:tcltk > grep -rI "\-offrelief" *
> gis.m/maptool.tcl:              -variable maptools($mon) -value pointer
> -relief flat -offrelief flat -overrelief raised \
> gis.m/maptool.tcl:              -variable maptools($mon) -value zoomin
> gis.m/maptool.tcl:              -variable maptools($mon) -value zoomout
> gis.m/maptool.tcl:              -variable maptools($mon) -value pan
> gis.m/maptool.tcl:              -variable maptools($mon) -value query
> gis.m/maptool.tcl:              -variable maptools($mon) -value measure
> gis.m/maptool.tcl:              -relief flat -offrelief flat -overrelief
> raised \
> raised \
> gis.m/georecttool.tcl:          -variable grmaptools -value selector
> gis.m/georecttool.tcl:          -variable grmaptools -value zoomin
> gis.m/georecttool.tcl:          -variable grmaptools -value zoomout
> gis.m/georecttool.tcl:          -variable grmaptools -value pan  -relief
> G:tcltk >
> checking Tcl version... 8.3
> checking Tk version... 8.3
> Error in startup script: unknown option "-overrelief"
>     while executing
> MapCanvas::poin
> ter $mon"  ..."
> Error in startup script: unknown option "-compound"
>     while executing
> "$zoommenu add command  -compound top  -label {Zoom to selected map}
> -command {MapCanvas::zoom_map $mon}"
>     (procedure "MapToolBar::create" line 72)
