[GRASS-dev] Re: should G_raster_map_type() use G_find_cell2() ?
Thu Oct 26 14:31:22 EDT 2006
Hamish wrote:
> perhaps more to the point,
> lib/gis/find_file.c
> the Doxygen header comments for G_find_file() and G_find_file2()
> each describe what the other function does.
You're misreading the comment for G_find_file2() (easily done, due to
the odd phrasing):
 *      Exactly the same as G_find_file() except that if name is in the
 *      form nnn in ppp, and is found, name is changed to nnn by G_find_file().
This is saying: G_find_file() changes the name, but this function
doesn't.
