[GRASS-dev] Re: should G_raster_map_type() use G_find_cell2() ?
Hamish
hamish_nospam at yahoo.com
Thu Oct 26 20:48:26 EDT 2006
Glynn Clements wrote:
> > lib/gis/find_file.c
> > the Doxygen header comments for G_find_file() and G_find_file2()
> > each describe what the other function does.
> You're misreading the comment for G_find_file2() (easily done, due to
> the odd phrasing):
> * Exactly the same as G_find_file() except that if name is in
> * the form nnn in ppp, and is found, name is changed to nnn by
> G_find_file().
> This is saying: G_find_file() changes the name, but this function
> doesn't.
ahh, ok. I've updated the comments in CVS to be clearer.
Hamish
