[GRASS-dev] Re: [GRASS-CVS] maciej: grass6/general/g.findfile
description.html, 1.4, 1.5
Brad Douglas
rez at touchofmadness.com
Fri Oct 27 04:28:22 EDT 2006
On Mon, 2006-10-23 at 21:28 +0200, Markus Neteler wrote:
> On Mon, Oct 23, 2006 at 09:17:58PM +0200, grass at intevation.de wrote:
> > RCS file: /grassrepository/grass6/general/g.findfile/description.html,v
> > +However, you can find a list of standard GRASS <em>element</em> names in the
> > +file $GISBASE/etc/element_list. This is the file which g.remove/g.rename/g.copy
> > +use to determine which files need to be deleted/renamed/copied for a given
> > +entity type.
> Hi,
> a style question: Up to now most GRASS documentation (HTML/MAN pages)
> say "the user", here "you" was introduced.
> Maybe it's a non-issue, but I feel that it the style of writing should
> be decided and homogeneous.
> Opinions?
It is best to avoid referring to the user at all. Ex:
"...However, a list of standard GRASS <em>element</em> names can be
found in the file..."
Brad Douglas <rez touchofmadness com> KB8UYR/6
Address: 37.493,-121.924 / WGS84 National Map Corps #TNMC-3785
