[GRASS-dev] call for last minute testers
    Michael Barton
    michael.barton at asu.edu
    Tue Oct 31 14:18:38 EST 2006
Otto,
I had sent in the wrong version of a georectifier update last night. I sent
in a new one this morning to Markus, who put it into 6.2. I just added it to
6.3 a moment ago. I don't know if this fixes the problem you are having, but
you might test it. Thanks for the info.
Michale
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Otto Dassau <otto.dassau at gmx.de>
> Date: Tue, 31 Oct 2006 14:05:13 +0100
> To: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] call for last minute testers
> On Tue, 31 Oct 2006 23:40:13 +1300
> Hamish <hamish_nospam at yahoo.com> wrote:
>> Hi,
>> Michael & myself have just applied some last minute patches to gis.m to
>> make it compatible with tcl/tk 8.3. As this will be released with 6.2.0
>> without much (any) testing, if everyone could quickly update gis.m in
>> their cvs (6.3 is probably fine, 6.2 branch is better- it's the same),
>> make, and double check that we haven't broken anything? (main toolbar
>> and the georectifyer canvas toolbar)
> Hi,
> using the "clear all GPC entries" button (in the georectifyer) after setting
> various GCPs only clears the first 2 columns of the first line, but the
> forward
> and backward errors remain with following error message (command name below is
> the RMS error in line 1 third col):
> invalid command name "0.590568"
>     while executing
> "$fwd_error($gcpnum) delete 0 end"
>     (procedure "GRMap::cleargcp" line 14)
>     invoked from within
> "GRMap::cleargcp"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel \#0 $cmd"
>     (procedure "Button::_release" line 18)
>     invoked from within
> "Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
>     (command bound to event)
> I tested with the 6.2 snapshot. Maybe someone can reproduce this?
> regards,
>   Otto
>> thanks a lot,
>> Hamish
