[GRASS-dev] call for last minute testers
Markus Neteler neteler at itc.it
Tue Oct 31 14:08:01 EST 2006
On Tue, Oct 31, 2006 at 02:05:13PM +0100, Otto Dassau wrote:
> using the "clear all GPC entries" button (in the georectifyer) after setting
> various GCPs only clears the first 2 columns of the first line, but the forward
> and backward errors remain with following error message (command name below is
> the RMS error in line 1 third col):
> invalid command name "0.590568"
>     while executing
> "$fwd_error($gcpnum) delete 0 end"
>     (procedure "GRMap::cleargcp" line 14)
>     invoked from within
> "GRMap::cleargcp"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel \#0 $cmd"
>     (procedure "Button::_release" line 18)
>     invoked from within
> "Button::_release .gcpwin.mf.topf.tb0.bbox1.b1"
>     (command bound to event)
> I tested with the 6.2 snapshot. Maybe someone can reproduce this?
I have submitted an updated georect.tcl from Michael to 6.2-CVS
and redone the CVS snapshot:
http://grass.itc.it/grass62/source/snapshot/
This should fix it (hopefully).
Time to release, we can always do 6.2.1 (even quickly) if anything
needs to be done.
Markus
