[GRASS-dev] d.vect.thematic problem
Michael Barton
michael.barton at asu.edu
Mon Sep 11 17:22:09 EDT 2006
It IS a path problem. It is getting set incorrectly, without
/usr/bin:/usr/local/bin...etc.
GRASS 6.3.cvs (spearfish60_test):~ > $PATH
bash:
/Applications/Grass/GRASS.app/Contents/Resources/bin:/Applications/Grass/GRA
SS.app/Contents/Resources/scripts::/Users/cmbarton/Library/Application: No
such file or directory
I set it manually and all works. Any thoughts?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: William Kyngesburye <woklist at kyngchaos.com>
> Reply-To: William Kyngesburye <kyngchaos at kyngchaos.com>
> Date: Mon, 11 Sep 2006 16:15:55 -0500
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] d.vect.thematic problem
> d.vect.thematic works for me. If I change that awk check to
> something that doesn't exist, I get the expected 'awk required'
> error. No syntax error.
> And, awk itself from the GRASS Terminal works for me. What's your
> PATH in GRASS at the time you want to run d.vect.thematic? Even
> without the user adding anything to the PATH in their bash startup, /
> usr/bin should be in their PATH.
> On Sep 11, 2006, at 3:41 PM, Michael Barton wrote:
>> Earlier today, I reported that d.vect.thematic is not running on my
>> Mac, returning the error
>> csh: if: Expression Syntax.
>> d.vect.thematic: awk required, please install awk or gawk first
>> The code in d.vect.thematic that is causing this is the following...
>> #### check if we have awk
>> if [ ! -x "`which awk`" ] ; then
>> echo "$PROG: awk required, please install awk or gawk first" 2>&1
>> exit 1
>> fi
>> If I run...
>>>> which awk
>> ...from the a plain vanilla bash Terminal.app window, it returns ...
>> /usr/bin/awk
>> But if I run it from the GRASS Terminal.app window, it returns...
>> This is with William Kyngesburye¹s binaries of 2 Sept. 2006. Any
>> idea what¹s wrong?
> http://www.kyngchaos.com/
> All generalizations are dangerous, even this one.
