[GRASS-dev] r.le bugs--list needed
Markus Neteler neteler at itc.it
Mon Sep 25 18:02:38 EDT 2006
On Mon, Sep 25, 2006 at 02:20:42PM -0700, Brad Douglas wrote:
> On Mon, 2006-09-25 at 14:51 -0600, William L. Baker wrote:
> > Hello,
> > I may (still uncertain!) slowly try to get r.le programs to work under
> > 6.X. Here is what I see as problems to be fixed. If anyone knows of
> > other problems, let me know:
> > 1. r.le.setup fails when a sitefile is requested--update needed
> > 2. r.le.setup does not display properly in the display window
> > 3. with gis.m, r.le.setup does not connect to display window
> > 4. r.le.pixel crashes with a memory problem
> > 5. no r.le.dist program
> William,
> r.le needs major work.  It has not been touched in several years and I'm
> a bit surprised that it still works at all.  I got a start on it last
> week by at least resolving compiler errors/warnings for r.le.patch, but
> I didn't really attempt to fix anything.
> Is there anyone who has the time to deal with r.le in the near term?  It
> will be a fairly time consuming project if you plan on updating text I/O
> (it references stderr, stdout, and files extensively).
> What happened to r.le.dist, anyway?  Would it be best to remove r.le
> from production branches (6.2) until it works reliably again?
hi,
please note that there are the r.li efforts:
http://www.faunalia.it/mediawiki/index.php/R_li
Maybe efforts could be joined?
Markus
