[GRASS-dev] discussion: replacing ps.map
William Kyngesburye
woklist at kyngchaos.com
Fri Apr 6 00:18:50 EDT 2007
I'm having a problem building libraster now. I get a bunch of
multiple definitions errors between the linked pngdriver and psdriver
when linking the raster library.
_true_color
_height
_width
_init_color_table
My last build was Apr 2, and successful.
On Apr 4, 2007, at 5:15 AM, Glynn Clements wrote:
> Having eliminated all use of the unscaled raster operations, I've
> removed them from the drivers, and moved the scaled raster operations
> into the drivers. This should all be transparent to the user but, like
> any change to the driver protocol, the changes are relatively
> invasive, so there's always the possibility of bugs creeping in.
> Also, direct rendering can now produce PostScript as an alternative to
> PNG or PPM files. The GRASS_RENDER_IMMEDIATE environment variable has
> been extended to accept values of PNG (generate PNG or PPM output,
> equivalent to GRASS_RENDER_IMMEDIATE=TRUE) and PS (generate PostScript
> output).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
