[GRASS-dev] [grass-code P][372] scritps for converting raster maps into GRASS 7 format, and back
grass-codep at wald.intevation.org grass-codep at wald.intevation.org
Wed Apr 18 05:38:38 EDT 2007
code P item #372, was opened at 2007-04-18 21:38
Status: Open
Priority: 1
Submitted By: Hamish Bowman (hamish)
Assigned to: Nobody (None)
Summary: scritps for converting raster maps into GRASS 7 format, and back
Patch status: postponed
Patch type: new
GRASS component: raster
GRASS version: None
GRASS CVS checkout date, if applies (YYMMDD):
Initial Comment:
r.convert and r.convert.all:
Converts a GRASS 4-6 raster map to a GRASS 7 raster map by moving files around in the $MAPSET.
Mostly untested, probably misses some bits.
I did not use g.message as I think it should be fully backwards-compatible with GRASS 5.0.0 and newer.
Tries to be really really cautious.
Hamish
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=205&aid=372&group_id=21
