[GRASS-dev] nviz crashes on MacOSX
Agustin Diez Castillo
Agustin.Diez at uv.es
Fri Apr 20 07:03:50 EDT 2007
I did NOT start from the terminal, I doubled click on the
application. The Xlib message only showed up once, the tcltk messages
several times but they are gone now. However nviz still crashes.
http://smigol2.uv.es/nviz_crashing.mov
On Apr 19, 2007, at 10:03 PM, William Kyngesburye wrote:
> On Apr 19, 2007, at 2:19 PM, Glynn Clements wrote:
>> Agustin Diez Castillo wrote:
>>> I did compile with TCLTKPREFIX=/usr/local/tcltk. At first it refuses
>>> to launch grass, if the terminal was already open nothing happened
>>> otherwise I got this:
>>> GRASS 6.3.cvs (Projecte):/Applications/GRASS-6.3.app/Contents/
>>> Resources > gis.m &
>>> Resources > Xlib: connection to ":0.0" refused by server
>>> Xlib: No protocol specified
>>> Application initialization failed: couldn't connect to display ":
>>> 0.0"
>> This implies that no X server is running.
> And supports my suspicion that Agustin started GRASS.app from the
> Terminal. GRASS.app is meant to be double-clicked to start. The
> GRASS.app startup adds some convenience items to start X11 and
> setup some environment var defaults appropriate for OSX. It should
> be possible to run this startup from the Terminal, but I haven't
> tested that and there may be problems.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070420/1f5d6ce3/attachment.html
